SIF VS Y connection in a B31.3 piping system
To be able to realize a complete stress analysis, I'm searching for a way to determine the ''i'' factor (Stress Intensificator Factor) of an unreinforced fabricated ''Y'' connection in a B31.3 piping system. Can you help me out?
Thanks in advance,
Hcjulien
Thanks in advance,
Hcjulien
RE: SIF VS Y connection in a B31.3 piping system
Conduct a FEA of the Y piece and calculate the SIF's from the results.
No problem to create a FEA analysis, but how can I still find the SIF?
What I was thinking to do is finding the Von Mises stress ratio : stress at the Y connection (at the weld) divided by the stress in a straight pipe (having the same diameter as the the smallest diameter in the Y connection). My ratio will be my SIF. The same design pressure with the same created Moment will be used for both stress analysis.
What do you think?
regards,
hcjulien
I understood SIFs to be based on fatigue.
