1" PVC water line under creek
Can someone please recommend the best method to place a 1" water line under a creek? Also, what about protecting the 1" line? Steel casing? A larger PVC pipe?
Bottom of creek about 4' deep, 10' wide.
Thank you.
Thank you.
RE: 1" PVC water line under creek
Richard A. Cornelius, P.E.
WWW.amlinereast.com
Is there a particular reason no one suggested jack/bore?
You asked for the most economical method. Jack & bore is not economical in this application.
WWW.amlinereast.com
