Cat TH62 3rd Service pressure drop
I was wondering if anyone knows if there is a way to either adjust it or what could be wrong as when we are using our wrapped bale cradle unless you keep your finger on the joystick button the pressure goes and it drops the bale also with our dung grab when you let goof the button it releases the pressure.
It has been suggested that it could be the ram seals but the ram stays as cool as a cucumber where they said if they are leaking it should get hot.
RE: Cat TH62 3rd Service pressure drop
It could also be a bad seal in the solenoid valve. If this is true you should be able to hold pressure on one side of the cylinder but not the other.
ISZ
ISZ
