ICC Reinforced Concrete Test
Hello All.
I am ready to take the ICC Test. A co-worker informed me that by taking the fire-proofing ICC first,a person does not have to submit a letter of qualifications for additional inspection licenses ?  Also was wondering if the 70 % requirement to pass test is for both the plan reading and code section or do they combine the scores ?
Thanks for the help ......
Peace.....
RE: ICC Reinforced Concrete Test
1) a person does not have to submit a letter of qualifications for additional inspection licenses ?
To obtain an ICC cert as fire-proofing Special Inspector: No.
The governing jurisdiction where the inspection will take place may require additional information prior to allowing you to inspect.
2)  Also was wondering if the 70 % requirement to pass test is for both the plan reading and code section or do they combine the scores ?
The fire-proofing exam is a one part exam.
Check the ICC web site and download the latest testing information bulletin.
http://www.iccsafe.org/certification/inspector/2009/pdf/2009National.pdf
