ASME Calculations
ASME Calculations
ASME Calculations
Does anyone out there peform calculations for changes to small low pressure boilers?  A colleague has a project involving re-rating some boilers from 15 lb steam to 30 lb hot water (they are not currently rated for hot water) and also installing larger nozzles for the water return line.  The boilers are Kewanee and Cleaver-Brooks.  He is looking for someone who is licensed and does this for a living or on the side.
Brian
RE: ASME Calculations
Promoting, selling, recruiting and student posting are not allowed in the forums.
http://www.eng-tips.com/market.cfm
Patricia Lougheed
"Somebody on this Internet forum said it was ok" is not a sufficient explanation when responding to a lawsuit.
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
1464649,
         Why not revert back to the original Equipment Suppliers as they understand their Equipment better than anyone else and should be able to assist in the modifications.
you need someone with an R stamp to re-rate and alterate the units.
talk to your jurisdiction inspection agency, they will be involved anyways
yes you can do it easily. looks pretty good and profitable.
do not forget about me...
