Falling Weight Deflectometer
1-How long does it take to perform each falling weight deflectometer test?
2-Any special requirement for airport testing?
RE: Falling Weight Deflectometer
The special setup for airport work is that you use a higher load set. The use of a heavy duty FWD would be better for airport work.
I am truying to estimate the time needed to do 20 tests at 20 different locations using HFWD.
Thanks.
