Sim Xpress v full version
I notice you can optimise the model in SimXpress - is there an option to do this in the full version?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Sim Xpress v full version
you need to run a study first ie a static case of wahtever.
then click on the assembly name and add a new study... at the bottom there is an icon with a screw and some nuts, that is the optimization mode.
There are three tabs to fill out. One will link the static case you just ran.
the other the parameters of your design you want to change, and with its upper and lower bounds
the third the target goal you want: ie> deflection needs to be 2.49mm to 2.51mm
and then just run it.
it will also do assemblies.
