6-Story Braced Frame Analysis
I am doing an Seismic Analysis on a 6-Story inverted Chevron Brace system, similar, to the Sabelli Report if anyone is familiar with that? The question i have is why did they have to include a "dummy column" - non Braced Frame Column to the system. As you can see from the attachment.
If anyone has an answer, please respond as soon as you can.
Tim
Tim
RE: 6-Story Braced Frame Analysis
Maybe if you posted a link to the report you would get more accurate responses.
I think you are talking about dummy column as in "zipper column" in the V bracing system. This was developed by Dr. Leon from Georgia Tech University. I attended a seminar and he said he did some studies that showed that dummy column (zipper column, thats what he called) would help in the overall strength of the system. I do not have any report to send you. But I do have his e-mail address: rleon@ce.gatech.edu
He is avery nice professor and I am sure will be able to answer your questions. Please do share back with us your findings.
I agree with SteelPE that it is likely meant to represent the "leaner" columns that contribute to the P-Delta effect on the braced frame.
Has anyone ever used this method for wind analysis?
