Minimum applicable working temperature
Dear All,
please let me know, the mimum applicable working temperature for P-265GH and P-245GH.is it possible to use them for -20C temperature? (thk.<16mm)
Thanks in advance
RE: Minimum applicable working temperature
farzam;
The Carbon Steel Handbook by EPRI is now available on the public domain. Locate a copy and you will find that the above pressure vessel steel grades under CEN standards are comparable to the following ASTM/ASME specifications;
CEN 10222-2 P245GH is comparable to ASTM/ASME A/SA 350 LF1
CEN 10222-2 P265GH is comparable to ASTM/ASME A/SA 516 Gr 60
Yes, both steels supplied to the above CEN standards can be used at -20 deg C.
