Ice Formation in PSV tailpipe
The possibility of ice formation in the flare system when high pressure wet gas stream from a separator is relieved to flare looks high.
If two-phase relief flow including the free water is considered, the situation looks worse. Does anyone know thow these scenarios are mitigated against? I can't imagine that winterizing alone, or relying on high relief velocities will altogether solve the problem.
RE: Ice Formation in PSV tailpipe
excuse for using lateral tees, since they tend not to plug with ice build-up.
