channel to shell gasket type at BEU HEX
I am looking for a suitable way of sealing channel to shell joint at a BEU vertical heat exchanger.
I have thought to use two ASME B16.5 flanges, for shell and channel, in combination with a typical spiral wound gasket of the same class.
As a result no o-ring or planiflex gasket will be used, as it was common to some HEX I have seen in past.
I want to know if the proposal joint method i.e. to joint HEX body flanges as it was piping components, is suitable
RE: channel to shell gasket type at BEU HEX
Mike
Cheers,
gr2vessels
