Petroleum Engineer Vs. Chemical Engineer
Hi.
Can anyone help me understand what a Petroleum Engineer exactly is? What does he do? I was thinking that it is simply another term for Chemical or Process Engineers...
THanks
THanks
RE: Petroleum Engineer Vs. Chemical Engineer
Petroleum Engineering has aspects of Chemical, Mechanical, and Civil Engineering. The "reservoir" aspect of the discipline deals with storage and transport of hydrocarbons through a semi-permeable media. Reservoir Engineers make extensive use of reservoir and fluid properties models to predict how much hydrocarbon is there, how much of that is recoverable, and how fast can it be extracted.
The "drilling" aspect deals with making a hole in the ground from the surface to reservoir depth. These guys are dealing with drilling fluids, materials selection in wellbore tubulars, and mechanically drilling a hole through rock.
The "completions" aspect deals with connecting a hydrocarbon reservoir with the wellbore. These guys are looking at the results of downhole data collection tools to determine where within the wellbore the reservoir should be connected to the wellbore by "perforating" the casing. These guys also design any required stimulation processes to enhance a reservoir's ability to give up hydrocarbons.
The "production" aspect deals with post-stimulation activities such as pumping liquids and separating liquids and gases.
See it is just like a Chem E inside a plant.
David
Some of us are CPR Engineers.
Petroleum engineers use the chemical engineering fundamentals and apply to the processes primarily related to the crude oil and all its sub categories. They study details of catalytic cracking, hydrocracking etc.
rmw
Now I know I can't apply for a job as Petroleum Engineer since I am a chemical engineer...
David
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
