Drawing
Drawing
I have two drawings on separate files. One of my drawing files has 4 sheets. I want to combine my other drawing into this one on the fifth sheet but can't figure out how to do this. I'm sure there's something simple I'm missing. Using SW08.
RE: Drawing
Insert new sheet.  Insert Model View then browse for the part/assembly that you want to use.
or
Insert new sheet then copy and paste the drawing views from the one drawing to the other.  This usually works but doesn't always depending on the type of view you are copying.
RE: Drawing
Ah...just got it to work. Just had to click on the part hit ctrl+c and then paste it into the other sheet.
thx
