transformer secondary fusing, dual output
I would like to use a 2 KVA single phase transformer to create both 115 and 230 single phase. I know to wire it to get these outputs. I am unsure how to fuse the 2 outputs. I need 5 amps of 115 and 8 amps 230. In the transformer I connect X2 & X3. X1 to X2 gives me 115 and X1 to X4 gives me 230.
Any suggestions??
Any suggestions??
RE: transformer secondary fusing, dual output
In NEMA land, put a 10 amp fuse (approximately 125% FLA) in the X1 and X4 leads.
The 13 amps on the X1 lead should blow the fuse before the transformer burns up.
Try again with the proper size transformer. 3 KVA and 15 amp (closest to 125% of FLA) fuses should do it.
Bill
"Why not the best?"
Jimmy Carter
