conversion of units
conversion of units
I'm looking to convert btu/hour/square foot into kWh/day. Is there a formula or technique for this? Thanks.
RE: conversion of units
http://www.engineering-4e.com
There is no formula or technique that will make an unbalanced ft^2 on one side disappear on the other side.
TTFN
kWh/day is essentially kW (the time units in the top and bottom essentially cancel out with a conversion factor).
BTU/hr is equivalent, unit wise, to kW so you need an area term for the kWh/day to be able to convert.
