info request about TSM 1424 Gr B
Good afternoon.
In the coal power plant I am taking care, there is a cast valve made of TSM 1424 Gr B: could you please suggest me what kind of material is that? do you have any datasheet?
The only thing I know is that it is a Cr-Mo-V steel, anything else.
Thank you very much for your help.
RE: info request about TSM 1424 Gr B
Your TSM 1424 listing of the valve does not look like a typical material standard designation for a valve. It might be a manufacturer model number and the Grade B could be their identification for a specific material type and Grade. How did you know this is a Cr-Mo-V casting? Did you contact the valve manufacturer and inquire as to the bill of materials?
