Help
Help
Can do convert from velocity vibration to aceleration vibration, directly or by a factor or procedure. I need to specify vibration values in acceleration, but references are in velocity terms.
Thanks.
RE: Help
And bear in mind that you cannot convert an rms velocity into an acceleration signal unless you know the frequency content.
Cheers
Greg Locock
