Fun found pipe in Dry system
This really isn't a question but more a picture we took of a dry system we were inspecting. Believe it or not the owner really thought it would be just fine.
This is a short piece of 2 1/2" pipe taken out of the end of a dry pipe line. We tried to flush the lines but after attache about 40' of additional pipe to get it outside the debris restricted the flow to a point that we couldn't get a reading on the pedo.
I just thought it was interesting.
RE: Fun found pipe in Dry system
Not so unusual in dry systems that have not seen regular inspections / maintenance. See my pic attached also.
So what did you do with the system? How did you go about cleaning it or did you replace some of it? In my experience, flushing a system with this degree of obstruction is next to useless.
Dave
Pretty nasty.
I have a garage project where an adjoining garage (same owner) has a dry pipe system and has a MIC problem - so much that the owner started having leaks within 6 months.
The owner has started to use nitrogen instead of compressed air to minimize the moisture introduced into the system.
My research indicates MIC can be a big problem in dry pipe systems.
At this point we are not sure how much of the system is affected. All of the points we have checked have been just like this.
Oh ya, I forgot to tell you my favorite part. The system is fed with a 6" ductile underground being reduced to a 4" OS&Y to the 4" dry valve. If you were paying attention there is no backflow device or even a single check valve installed.
Makes me glad I don't live there.
