Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I am so glad that I found your site, it is an excellent resource and has helped me greatly..."
Geography
racp12 (Mechanical)
28 Jul 09 14:41
Regarding API 650, 11th ed. with Addendum 1, I am doubtful about some statements regarding wall thickness.
According to para. 5.6.4.2,"required shell thickness for each course shall be the greater of the design shell thickness plus corrosion allowance (t1d) or the hydrostatic test shell thickness (t1t), but the total shell thickness shall not be less than the shell thickness required by 5.6.1.1, 5.6.1.3 and 5.6.1.4".
Under appendix K, para. K.2.1,for wall thickness calculation in accordance with the variable point method, for the hydro test condition, t1=t1t, and t1<= tpt
But, following 5.6.4.2, what if t1d is greater than t1t? I have tried to calculate wall ticknesses for a 44 m diameter, 21 m tall atmospheric tank. Checked calculated values for first course are t1t=22.06 mm and tpt=21.46 mm. This is not logical according to App. K.
Taking into account these results, it appears that there is a conflict between the mentioned paragraphs.
I insist, the calculations have been checked. I would like to know either if my interpretation is right or if there is a conflict in the code
JStephen (Mechanical)
29 Jul 09 8:18
I think API-650 is saying that for the test condition, t1 need not be greater than tpt, not that it will always calculate smaller.
rab1944 (Structural)
30 Jul 09 10:12
If you had a very light design specific gravity, the test condition (tt)could conceivably be of a greater thickness than that of the design condition (td).
racp12 (Mechanical)
2 Aug 09 22:46
rab1944,
Fluid is methanol. Specific gravity is 0.77
3 Aug 09 13:47
This is not enough information.  Pick you material, get your Sd and St stresses from Table 5-2b, make sure the material is appropriate for the design metal temperature and run it through the 1-foot design in Section 5.6.3.  I hope you the best.
Close Box
Join Eng-Tips® Today!
Join Us             Close
