Inverted Pipe Flows
Inverted Pipe Flows
Inverted Pipe Flows
Can HydroCAD model inverted pipe flows? If, so then how?
RE: Inverted Pipe Flows
Hydrocad won't allow you to enter an upstream invert that is lower than the downstream invert. How would HydroCAD model this situation?
Actually, HydroCAD will model a culvert with a reverse slope.  Just enter a negative slope, or an outlet that is higher than the inlet.  In addition to the normal culvert analysis, this will cause HydroCAD to consider weir-flow conditions at the outlet.
Note: This applies to a culvert outlet from a pond, not a pipe reach.  Since a reach always operated under normal Mannings flow, it must have a positive slope.
Peter Smart
HydroCAD Software
www.hydrocad.net
As to your second questions, HydroCAD will allow an upstream node to be lower than a downstream node.  This situation will generate a warning message to alert you to the tailwater condition, which can be handled by using the appropriate routing procedure and modeling approach.  You can click the specific warning message for further details.
Peter Smart
HydroCAD Software
www.hydrocad.net
