Stair Stringer Unbraced Length
When designing stair stringers for typical 46" wide steel stairs , do you consider the length of the stringer fully braced by the treads and risers.  In most cases the treads and risers are welded to the stringer with L1.5x1.5.
RE: Stair Stringer Unbraced Length
I have analyzed a lot of stairs for forensics investigations and have designed stair stringers.  I consider the stringers to be fully braced by the treads.
The referenced threads come to essentially the same conclusion.
The stair system starts emulating a Verendiel Truss system.  Hence the lateral bracing...  Sorry for the spelling - it's too hot to get up and look it up. sadeyes
Mike McCann
MMC Engineering
