How to insert a block from external drawing to current drawing?
My intention is insert a block "B2" from a external drawing test.dwg to current drawing. The problem is the whole drawing test.dwg was inserted in the current drawing. I know I am confused with "add a reference" and "add a block" but I don't know how to solve it. Seek help. Here is my code:
Sub InsertExternalBlock()
    Dim InsertPoint(0 To 2) As Double
    Dim insertEXTBlock As AcadExternalReference
    Dim PathName As String
'Insert point
    InsertPoint(0) = 1: InsertPoint(1) = 1: InsertPoint(2) = 0
'External drawing path which contains the blocks I want to insert
    PathName = "C:\test.dwg"
'Add block to the drawing
    Set insertEXTBlock = ThisDrawing.ModelSpace.AttachExternalReference(PathName, "B2", InsertPoint, 1, 1, 1, 0, False)
    ThisDrawing.Application.ZoomAll
   End Sub
RE: How to insert a block from external drawing to current drawing?
Hi microwave2009,
Autodesk doesn't allow this via VB/VBA.  You're actually almost home with your approach.  You'll need in insert (not AttachExternalReference) the drawing test drawing to get the definition of the block B2 into the drawing, and then insert block B2.  The other option is get into your test drawing and wblock B2, and then insert B2 from it's file location.
HTH
Todd
Are the two drawings .dwg or .dxf files?
