Vertically downward output shaft
In general - Is there an oilseal that could cope with a vertically downward output shaft, or do all "designed" boxes have weirs and grease on the lower bearing on this type of unit e.g. mixers, agitators etc?
Cheers
Mick
Cheers
Mick
RE: Vertically downward output shaft
No-leak drywell design physically separates the oil sump from the output shaft to eliminate gear oil contamination of your product.
Russell Giuliano
Weirs, drywells, etc, are the logical evolutionary response to a perceived or real need to avoid contamination of whatever is being mixed even when the oil seals leak.
Need a super-short box?
Can afford regular preventive maintenance?
Are really tall when you're sitting on your wallet?
Given that last, nearly anything is possible.
Mike Halloran
Pembroke Pines, FL, USA
