standards for building near an existing quarry
I'm from Jersey and understand that there are state standards on the blasting in quarry's. My question is ..Are there any state standards on building foundations on property adjacent to an existing quarry? This property in question is on steep slopes and rock outcrops.How could you build foundations to handle the constant blasting from the quarry?
Thanks!
Thanks!
RE: standards for building near an existing quarry
It is POSSIBLE to design foundations to resist vibrations. Measures will include increasing the mass of the foundation significantly, and mounting the structure on (for example) neoprene pads. However, this is very expensive.
It would be better to limit the vibrations by appropriate blast design AT THE QUARRY.
Why are you building close to an operating quarry? Building on a steep slope close to a quarry seems to ignore the forces of nature. Can you be sure that blasting vibrations reaching the slope(s) will not initiate failure, even in the softer overburden material?
If the building already exists, and the quarry is advancing towards the building, check the planning permission for the quarry. Is it permitted to advance so far? Are the vibrations limited in any way? Even if you find no protection from these sources, the quarry manager still has a duty of care not to damage your property. You could start monitoring vibrations or measuring existing cracks in your building. A joint monitoring operation with the quarry would be ideal. If you can get the quarry to pay for this monitoring, all the better.
I appreciate your reply. The questions that you have asked me are the same questions that I am asking the engineer at the planningboard level.
I'm not the one developing the property. A developer wants to develop 370 townhomes on this property.I have repeatly asked them about the impact on these foundations from the quarry blasting. They keep replying that the quarry has standards to follow and it's not their problem to worry about the blasting.
Maybe you can give me pointers as to what I should ask and look for. Thank you so much.
Chuck
cgopperton@stantec.com
http://www.stantec.com/
Without being involved in the detail of the proposals, my instinct would be to be very suspicious of the development proposal. The development might be much more appropriate when the quarry has ceased operating. I would not really want to move to an area where there was going to be regular blasting with the attendant vibration and air over-pressure. Note that the human perception of these is very sensitive, and we will notice (and get annoyed about) phenomena which will have no significant long term effect on buildings.
Is the quarry going to object to the development on the grounds that it will lead to unreasonable restrictions on their work in the future? Any future planning application by the quarry may be affected by the presence of the new development, because planners will wish to protect this from any new quarrying proposals.
IF the houses are at all affected by the blasting operations, who is liable? Is the developer able to avoid all liability? If so, this may be what makes the project attractive.
The issue is complex. However, the developer MUST worry about the blasting, as the blasting is part of the environment in which he is constructing the new houses! He must address the concerns, and the planning authority should be raising these and other concerns with the developer at the same time as liaising with the quarry. It's essential that someone see the big picture, understand it, and act on it. "cvg" is right, all parties need to raise their heads out of the sand (if that's where they are) and communicate with the others.
Consider:
what limits are placed on the quarry and at what locations;
the distance of the nearest proposed house from the present and ultimate blasting front;
whether the limits on the quarry are appropriately policed;
what confidence there is in the adherence of the quarry to limits;
whether the quarry will really be liable if there is an accidental exceedence which can be proven (difficult to prove!!!!) to have caused damage to one or more properties;
whether the quarry could meet its liabilities in such a case.
The local authority planners must avoid contributing to a situation where people are persuaded (by the developer) to buy houses which are vulnerable to damage caused by someone who will not or can not provide reparation, especially if the developer - knowing of the vulnerability - also avoids liability.
Local estate agents and solicitors ought to ensure that appropriate checks and searches are carried out for potential purchasers for protection of the purchaser in the deeds or under statute. (Compare with flood damage potential.)
Good luck with this. I'm not sure what role you have in this, but there appear to be genuine causes for concern - WHICH MAY BE ADEQUATELY PUT TO BED EVENTUALLY - which must be addressed BY THE HOUSING DEVELOPER.
