SW 2009 Colors and Appearance
I want a part to be white. When I open the appearance property manage and select white color for the part, I get a slightly lighter shade of gray (the default color). In 2008, this usually meant I had a color set for the feature or surface as well. This isn't the case here. Least not that I can tell. I have tried setting different appearances, it might add a texture, but the 'graying' out still happens.
Can anybody help me out here?
RE: SW 2009 Colors and Appearance
Artem Taturevich, CSWP
Software and Design Engineer
AMCBridge LLC
www.amcbridge.com
White has always shown in a gray color for me. The issue with not being able to color the knurling texture is a limitation (or regression) of the "new" way of doing things.
Rob Rodriguez CSWP
www.axiscadsolutions.com
www.robrodriguez.com
http://www.robrodriguezblog.com
Eastern Region SWUGN Representative www.swugn.org www.nvtswug.com
SW 2007 SP 2.0
You can find the old textures in /solidworks/data/images
I made a copy of the texture and opened it in snagit editor, did a fill with the color of my housing with a 75% tolerance and 50% transparency. Then did a stretch intensity. Browsed to the new texture in the appearance property manager.
You could get a free version of snagit 7 just for giving them an email at one time. I used 9 in this case not sure if 7 has the same options and I am sure something like photoshop would work much better.
