Tank Nozzle
Tank Nozzle
Is there any drawback if ERW pipe nozzle is used on the shell of atm water tank for more than 24" diameter size of nozzle?
Thanks in advance for assistance.
RE: Tank Nozzle
Above 24" your only choice may be ERW, so if the additional longitudinal weld is a problem then you need to mitigate it through choice of material, or applied protective coating.
Cheers,
John
RE: Tank Nozzle
36" nozzle is from ERW pipe at site you are present?
RE: Tank Nozzle
Cheers,
John
RE: Tank Nozzle
RE: Tank Nozzle
jt
RE: Tank Nozzle
