Dimensions Drawings for the Laser
Now that it is possible to transfer information digitally from a CAD package directly to a laser for cutting parts from sheet metal or plate, how many of you still completely dimension the drawings? If you don't completely dimension the drawings, what sort of dimensions, if any, do you show on the drawings?
Phil
Phil
RE: Dimensions Drawings for the Laser
If the cad data is available I see no reason to create a cluttered drawing. Include the information needed to inspect the part to the level you need to be satisfied the part is good.
> Presumably, most laser cutting systems will have a pre-processor that would take CAD data and format it accordingly for a cutting process, including corner and kerf corrections.
> Dimensioned drawings are specifically for human consumption, so while one might transfer a CAD database for fabrication, a dimensioned drawing would be required for human inspection and verification that the part meets its intended requirements, which might be quite distinct from the fabrication data.
TTFN
