standard parts library 674bit
hi all,
Since a few weeks we've migrated from SE 32bit to SE 64bit.
Now the "SE standard parts library" doesn't work with 64bit.
Does anybody know of an alternative we can use?
Evert
Solid Edge ST 64bit
Windows XP x64
RE: standard parts library 674bit
Do you have 32bit Standard Parts database yet?
If yes. You should copy this all folder (Solid Edge Standard Parts) onto your pc. After this you should define the path of the smapinifile.sac (Solid edge button--> Solid Edge option--> File locations).
It will work!
Note: Parts administrator dosen't support 64bit in ST, but it will in ST2!
Good luck!
