soket weld check valve
how to maintain and replace sw check valve ?
RE: soket weld check valve
Ha.  Put it within screwed or flanged pups.
"Pumping accounts for 20% of the world's energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies) http://virtualpipeline.spaces.live.com/
thanks Biginch, but I never saw this before. I thought SW check valve doesn't need maintain.
If its got moving parts, its just a matter of time and severity of service.
Install one with a bolted bonnet?
some check valves have a top cap which can be taken off to remove the plate and pivot assembly for service
Install unions up & downsteam of the check valve. Unions are probably part of your piping spec. and would allow removal of the check valve
normally sw check valve is 2" and below, it doesn't serve frequently, such as surge, blow down...so, I guess this is the reason there is not a removeable pup, we can fix smalll problem on site by opening the top cap. but if it is used in frequent operation place, it has to have removable pup.
am I right, guys?
Must admit that a flanged pup defeats the reason for using socket welds in the first place.
