request for macro link
I am using a macro called "propigate custom property" to pull custom properties to a drawing from the part or assembly model.  It works good, but is limited to the global properties and does not pull properties from any of the configurations.
Does anyone know of a similar macro that one can first select the configuration, or pulls configuration specific as long as that config is in the drawing?
Paul
RE: request for macro link
Could you post this macro?
I believe it is posible to modify an existing macro to satisfy  your requirements.
Artem Taturevich, CSWP
Software and Design Engineer
AMCBridge LLC
www.amcbridge.com
