802.11g 1 watt transmitter
Does 802.11g broadcast in the microwave region?
I would like to buy a 1 wat outdoor type 802.11g transmitter booster ( connects to an AP). Would there be any health risks putting the unit and antenna in the room next to me? They tell me they will broadcast 3,000 ft. Surely it will not be able to receive from that far away..or will it. Your thoughts on the subject.
thank you
thank you
RE: 802.11g 1 watt transmitter
It is microwave at 2.4 GHz.
The unit will work a lot better if you can get the antenna outside of the building.
www.MaguffinMicrowave.com
Maguffin Microwave wireless design consulting
The 1 watt won't be CW also, don't worry about it for danger.
kch
