Can't view TUTORIAL...
RE: Can't view TUTORIAL...
this might failure might be an improperly registered .dll
that the tutorials need. You may try this
- in Windows --> Start -> Run
- into the pulldown key in this:
     regsvr32 -u HHActiveX.dll
  and press OK
- now put into to pulldown this:
  regsvr32 %windir%\system32\HHActiveX.dll
  and press OK
HTH
dy
Thanks donyoung for your suggestion. However, I am not able to try it because I have fixed the problem this morning. The problem was solved after I installed Adobe RoboHelp v8. May be during the installation, the HHActiveX.dll was registered again.
donyoung,
I have the same issue as onemilimeter - that is I can view the 3d object, but not the turorial.  Tried the registry patch you suggested, but it did not work.  The registry may be the problem because I ran Glary Registry Utilities and it just may have clean-up the registry I needed to view my tutorials.
If anyone has a suggestion as how to attack this, it would be appreciated.  Thanks - MechE2
Try installing the Adobe RoboHelp.
onemilimeter,
Thanks much for the suggestion and I started to download this program (got about 1/2 way) when I thought otherwise and decided to cancel.  My thoughts were that this is a publishing program, which I really did not need and that using it for this purpose addressed the symptom, but not the cause.  So I am searching for a solution that addresses the problem and then a specific solution.  Having said that, I do very much appreciate your suggestion and I will use it within the next week or two if I cannot find something more specific. - MechE2
