Do air operated piston pumps require a pressure relieve valve?
I'm wondering, if I need a pressure relief valve, for an aplication where I transfer oil from a tank to another.
I'm planning to use a graco air operated piston pump, with a 4:1 relation.
Cutsheets from graco don't shown a pressure relief valve, but I was recommended to use it. How ever, I understand that this pump will stop if a high pressure is reach, so i don't see the need to use it.
Am I OK?
Am I OK?
RE: Do air operated piston pumps require a pressure relieve valve?
Johnny Pellin
Bill
"Why not the best?"
Jimmy Carter
