Goal Seek Excel
Goal Seek Excel
Goal Seek Excel
thread770-224290: Automatic goal seek
Hello handleman
My question is similar to the thread  but it is a very basic question to do with incorporating your goal seek code into Excel in the so it runs automatically each time cells are changed instead of having to run a macro
My example
Goal seek by Setting cell C6 to 5,000  by changing A5
What I need to know is where you insert the VBA code – it does not work when I simply paste your code in the macro editor for an existing recorded macro. So I would be very grateful if you could assume that I am starting from scratch and have no macro at all and outline the steps I need to take as a basic excel user
RE: Goal Seek Excel
Here's one I use to iterate thru the Fanning Friction Factor.
This would be in the worksheet VBA & a "selectionchange"
Private Sub Worksheet_Calculate()
  If IsNumeric(Range("error")) Then
  If Range("error") <> 0 Then
    Range("error").GoalSeek Goal:=0.0000000001, ChangingCell:=Range("assum_F")
  End If
  End If
End Sub
RE: Goal Seek Excel
Thanks Psafety
Unforunately I do not program in VBA so Could you please outline in a step by step manner what I need to do in Excel/VBA editor/macro to have an automatic  goal seak update in an excel worksheet using teh example I gave . Thanks again
RE: Goal Seek Excel
  If IsNumeric(Range("c6")) Then
  If Range("c6") <> 5000 Then
    Range("c6").GoalSeek Goal:=5000, ChangingCell:=Range("a5")
  End If
  End If
End Sub
