SW claiming to run out of memory causing network issues
A bit of a strange one I can't figure out
A couple of guys here are getting messages on their stations that SolidWorks does not have enough resources to complete the required task (it's a message telling you to close other applications to free up resources, I can't remember the exact wording)
Weird thing number one is it seems to be happening when SolidWorks isn't using anywhere near enough ram to crash (normally about 1.7Gb on a 32 bit machine), this is happening even when SolidWorks is using about 300Mb of ram.
Weird thing number two is that when this starts happening the user loses all network connectivity.
The machines having this problem sometimes get blacked out toolbars and a black SolidWorks background, I don't know if this is related.
Any ideas? I can't see how memory and connectivity can be related, so any help on that would be great.
RE: SW claiming to run out of memory causing network issues
Could be power supply, bad RAM, insufficient VM, graphics card/driver, corrupt part/assy, .........
Can you list the complete system specs of the 'problem' machines?
Also list the stats for the assys being worked on.
Are you working across a network when editing files, or locally? PDM?
Dell Precision PW390
Intel Core 2 6700 @ 2.66GHz
2Gb RAM
Quadro FX 3450/400 SDI
It's been happening with all sorts of drawings / assemblies / parts, they don't have to be anything majorly complex
we use PDMworks
TOP
CSWP
BSSE
www.engtran.com
www.niswug.org
"Node news is good news."
Does the network go back to working once SolidWorks is closed?
Eric
http://kc
Joe
SW Office 2008 SP5.0
P4 3.0Ghz 3GB
ATI FireGL X1
Are the systems saying they are running out of Desktop Memory?
This happens when you have a bunch of apps, windows, files open. Windows only allocates so much memory to the Desktop (all the windows you have open).
2 gigs of memory is not that much on a cad system. We haven't run with less then four gigs of memory in the past 5 years or so.
I would get some more memory for your systems. Also make sure your users do not have a ton of windows and files open all the time.
You may want to get in the regular habit of shutting down SolidWorks a couple times during the day. Lunch and when you go home at night. Also restart your computer every night. This will clear up space dust that builds up while the systems are running.
Cheers,
Anna Wood
Anna Built Workstation, Core i7 EE965, FirePro V8700, 12 gigs of RAM, OCZ Vertex 120 Gig SSD
SW2009 SP3.0, Windows 7 RC1
http://www.solidmuse.com
http://www.phxswug.com
What version and SP of SolidWorks are you running?
Do you have the correct SolidWorks approved video card drivers for your systems and version of SolidWorks?
http://www.solidworks.com/sw/videocardtesting.html
Use the dropdown for Dell.
Cheers,
Anna Wood
Also, do you notice Draw Compare running?
rfus
I'll have a look to see how many windows these guys have open next time, i agree that 2Gb isn't much these days, it won't be a lot of money to get it up to 4. We generally turn our machines fully off every night
We are currently running SW2009 SP2.0, and one of the machines in question has the latest SW recommended graphics driver
I don't know anything about dissection, i take it i'll find that in the task manager?
Draw compare, now that's another thing. whenever i start task manager with SolidWorks running, task manager itself always seems to come up as draw compare, that's even on my machine, which is a totally different spec and doesn't get any of these problems
In the end we removed the Norton antivirus and switched to AGV and hade no more issues
Jim Self
SW09 SP2.1
Dell Precision 670
3GB Ram
Quaddro FX 3400/4400
dlplimited.com
I am so not surprised by that. LOL. I just changed mine as soon as I read your post.
Joe
P4 3.0Ghz 3GB
ATI FireGL X1
