335 HP Motor for Auto Shredder
I have a Schorch Motor (60 Hz, 250 kW, 480V, 360 A, 335 HP). I am trying to find a direct substitute for this motor. Can I get some suggestions on manufacturers or a dealer in/around the Texas area?
I'm currently trying to repair this one but will need a spare in case something happens to it. The Schorch was manufactured in 2005 and but we didn't actually start the auto shredder until 2006.
Thank you!
Thank you!
RE: 335 HP Motor for Auto Shredder
Type KA2319L-RZ01Z-Z IEC 315L IMB3 2005 Nr 20612402/1
3~ MOT 1P55
Th,C(D or G) F
UVW
60 Hz 335 HP
250 kW NEMA Design A
S1 Code Letter G
480 V
360 A
cos - 0,86
1188/min
bearing,C 6319 C3 En60034 IEC60034
bearingN, 6319 C3 Made in Germany
per bearing after 7400n/45g grease
DIN 51825-K3K Li-
dosp/mineral-oil 6154540
The 315 in the frame number is 315mm shaft elevation and the L is for long length along the shaft. There are also S and M for short and medium.
Seeing this new information, I am sure that ABB Motors Group in New Berlin WI will bid on this motor. Phone is 800-752-0696.
Siemens Europe would probably build a motor to this spec for you - maybe an option to explore through Siemens US.
Also, the rpm's are 1188 for this motor....just found that out.
"If I had eight hours to chop down a tree, I'd spend six sharpening my axe." -- Abraham Lincoln
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
Get the general drift here???
So let's study those mechanical mounting specs before deciding to discard the motors made in your own backyard.
The part number ends with a "-Z" and this is very Siemens-like indicating there is 'something special' about it. Usually tracing the serial number will indicate to the factory (Schorch) that the "z= xxxx" (something).
As DickDV and edison123 point out, check out the complete motor before assuming it is a straight replacement.
Thee is a Schorch outlet in Texas on the link jraef provides.
