Configuration Saveas Macro
I have a part file with say 20 configurations that I want to "saveas" to different file types. Is there a macro available that would break out the configurations into a specific file type?
RE: Configuration Saveas Macro
Meantime try the attached SplitConfig macro.
This is from CADimensions. (a VAR)
Joe
SW Office 2008 SP5.0
P4 3.0Ghz 3GB
ATI FireGL X1
Best regards, Mike
Could you show us the line that you changed, and what you changed it to? I've always split the config's, then do a "save as" manually.
Joe
P4 3.0Ghz 3GB
ATI FireGL X1
name = fname + "-" + configs(i) & ext
To ( .sat could be .stp or .igs or any extension you want):
name = fname + "-" + configs(i) & ".sat"
This is my new favorite macro...
Thanks. After I asked, I did find a macro I had saved that does this. DocExport from http
This one allows you to select which configs you want to export, in the event you don't need all 20 of them.
Joe
P4 3.0Ghz 3GB
ATI FireGL X1
