Changing Transparency
I have an assembly with about 30 parts and sub-assemblies, and when I try to make one of the parts transparent, it works, but if I click on anything else it automatically makes it a solid again. How do I make it continously transparent?
RE: Changing Transparency
There are some System Options that control assembly transparency. Maybe check into this and make sure those settings aren't over-riding what you do within your assembly. (?)
Jeff Mowry
www.industrialdesignhaus.com
A people governed by fear cannot value freedom.
And I can assure you its not the graphics card or the driver.
cp3, what SW version and SP are you running, also OS and 32 or 64 bit?
Im using SolidWorks Premium 2009.
Sorry, but Im not sure what SP or OS mean.
I dont think it has anything to do with my computer or any of the software I have. Because I can click on it, make it transparent, and it works fine, I can even rotate and zoom in and out. But as soon as I click on anything.. Literally anything, and it changes back.
Dan
www.eltronresearch.com
Dan's Blog
cp3, No need to apologise!
SP= SW Service Pack number, OS = computer's Operating System (Widows/Vista/Mac, these have SP's too and can make a difference).
WTF?
Have a look under your Programs listing, find the SolidWorks Program group, then the SW program itself, from this you should find "SolidWorks Tools" and in this run the "SolidWorks Rx" Program and hit the Diagnostics Tab, this will list your Graphics card at the top and there's a link to see tested cards.
Hope this helps.
GeForce 6600/PCI/SSE2
And the reason I said earlier that it wasnt my graphics card is because I figured that since I can see parts in transparent mode and rotate them around, that it wouldnt be a graphics issue. But maybe Im wrong.
I thought it would be a simple option that I clicked on accident. Because Ive had solidworks for several months, and Ive never had this problem before.
Check here for approved cards/drivers:
http://www.solidworks.com/sw/videocardtesting.html
Jeff Mowry
Jeff Mowry
It disappears entirely from the list as of v2008.
Jeff Mowry
Is it because the assembly that I can do it in is alot smaller than the one that I cant do it in?
For serious production work, check into some of the other cards, as listed at the SolidWorks site. I've seen lots of folks posting lots of problems with the nVidia Quadro cards lately, so I'm not sure I'd recommend that direction.
I run an ATI FireGL V5600 on this system and it works great with v2007, v2008, and v2009 of SolidWorks. (ATI used to produce cards that really weren't very reliable with SolidWorks, but they seem to be on top lately.) Cards like this will run several hundred dollars, but you'll avoid hassles of the type you're seeing now--plus you can essentially have as many parts open as your RAM will allow.
Jeff Mowry
Oh, on a side note, what if I created more sub-assemblies so as to avoid using so many parts? Would that help at all?
Jeff Mowry
Dan
Dan's Blog
I think that's very likely!
I've had occasions where it seemed it HAD to be a corrupt assembly file or something and NOT the card (which was an approved ATI GL) as similar assemblies, some even bigger would be fine, but the then SW 2007 would often (but not always) suddenly exit to the desktop without warning when working on this assembly only. I downloaded a new driver, later but not yet tested and the problem was gone.
Trevor Clarke. (R & D) Scientific Instruments.Somerset. UK
SW2009x64 SP4.0 Intel Core i7 2.94Ghz, 12Gb Ram, NVIDIA Quadro FX3700 Driver: 6.14.11.8246
SW2009x64 SP4.0 Intel Core 2 Duo 3.17Ghz, 8Gb Ram NVIDIA Quadro FX3700 Driver: 6.14.11.8246
Then see if you can turn the switch on.
What this switch does is totally bypass your video card. The cpu will handle the graphics. You will likely get a performance hit, but if your transparancy issue goes away you will know your graphics card is the culprit.
Cheers,
Anna Wood
Anna Built Workstation, Core i7 EE965, FirePro V8700, 12 gigs of RAM, OCZ Vertex 120 Gig SSD
SW2009 SP3.0, Windows 7 RC1
http://www.solidmuse.com
http://www.phxswug.com
