ABS to PUR bond failure
We are having ABS to PUR bond failures on our impact door assemblies. ABS cover sheets are roll coated with PUR and assembled to "core" and held in a press in a controlled environment per PUR supplier recomendations for temp, humidity. ABS sheets completely delaminate from PUR at random, 2 of 40 sheets today, leaving the cured PUR fully bonded to the core materials, Polyester scrim, wood and PVC
RE: ABS to PUR bond failure
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
As Pat mentioned, oils may be present. Silicone oil and other oils are added to some ABS and they would ruin adhesion.
Assuming you have cleaned the surface so that the first two problems above do not apply then the exact type of ABS will have an effect. ABS can contain different amounts of acrylonitrile in the SAN copolymer, that affects polarity and thus adhesion. So try different grades and ask your suppliers.
Try corona treating the cleaned sheets to increase surface polarity and bonding.
Chris DeArmitt
"Knowledge has no value except that which can be gained from its application toward some worthwhile end."
Think and Grow Rich - Napoleon Hill
You also might look at an abraded surface to improve the bond.
The use of Corona treatment to promote bonding as mentioned in the previous post is available as Corona treated ABS sheets.
Flame etched sheet should also be available.
You also may want to contact Spartech about their line of alloy plastic, as in your case a preformed sheet of PUR/ABS to eliminate one possible bonding line failure.
http://www.reltekllc.com/index.html
http://www.spartech.com/alloys.html
supplier response is due as to the manufacturing process and BOM component %'s and additives.
Etching is NG.
We have an independent lab anaylzing the material.
We arew studying Corona treatment.
Same random issue with textured surface.
We are having a brainstorming session with PUR adhesive supplier, ABS supplier, Environmental controls equipment supplier to confirm all process parameters are satisfied. Materials information (PUR and ABS) to be discussed in detail.
Thank You!
