Cyclic symmetry in Cosmos
thread1183-137543: Symmetry on rotating part
There are a few special cases where CosmosWorks will get this right. But in general CosmosWorks, Cosmos Simulation and DesignStar will not do this correctly.
The key is restrained properly. The only way you can do this is to have the same node pattern on both symmetry faces and to have the displacements coupled between the nodes on those faces. Even Cosmos/M has trouble with this.Quote:
I disagree. CW can accurately analyse cylindrical-symmetric models in pie sectors, if it is restrained properly.
TOP
CSWP
BSSE
www.engtran.com
www.niswug.org
"Node news is good news."
