Where to find a list of all "CRW5" SKF Radial Shaft Seals?
I'm creating an ordering spec for my company for type "CRW5" radial shaft seals from SKF. Although we could just use SKF's part numbers, having our own spec aids in documentation and certification. I would like to know of a source that lists all size of this type of seal. Any help is greatly appreciated.
SKF has proved to be no help, I got the run around, and then was told that they don't have this information. The only way they would help me is if I gave them a shaft size and then they would tell me everything they make in that size.
RE: Where to find a list of all "CRW5" SKF Radial Shaft Seals?
Awaiting for your advise
Ben
