1,200 degree F - FDA - Wear Rail
Good Morning,
I have an FDA application. A heater element that reaches 1,600 deg f. located 4" above the a 303/304 Stainless Steel belt. I need a wear rail for the belt that won't melt. We are leaning toward a non-metalic component so we dont get micro-particles from metal on metal.
Any help would be greatly appreciated.
Dan
Dan
RE: 1,200 degree F - FDA - Wear Rail
It would be handy to know what temperatures you would expect the part to attain.
www.tynevalleyplastics.co.uk
I assumed 1,200 f as the elements are generating 1,500 to 1,600 f at 4" away.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Looks like you will need a ceramic "wear rail", but it probably won't wear.
Thanks for the help,
Dan
Dan - Owner
http://www.Hi-TecDesigns.com
Pat
for site rules
My comment was steered more towards MB's query about FDA-approved ceramics, though whether those approved ceramics also handle that high of a heat is beyond my knowledge base.
Dan - Owner
http://www.abresist.com/ABRESIST_Linings.htm
This example is resistant to heat lower than what you are looking for but it's a start....
