AC Motor is Humming, Vibrating
Hi All,
I'm trying to figure out why the ac motor that I'm working on is giving a humming sound, vibrations when I turn ON the power switch. I have to give it a kick or a pushing turn to help then it runs fine. When I turn the switch to OFF position and when it stops spinning, I can hear the click like locking or braking the rotor, I think. Please advice and give me some tips to make this motor running again when the switch is turned ON. Thanks in advance! Have a nice day!
RE: AC Motor is Humming, Vibrating
1> Your switch is not making contact when it should due to dirt or corrosion.
2> Your starting winding is burned out.
3> Your starting capacitor (if you have one) is faulty or disconnected.
4> You have a wire broken or disconnected.
5> More than one of the above faults.
Bill
"Why not the best?"
Jimmy Carter
I checked the switch when turn ON, yes there's current.
Dissembled the motor and cleaned inside. Yes I see some corrosions. I used air gun to blow it out. Put back everything, still the same results. Humming and vibrating.
I still hear the click
Do you know the place or links that I can order the motor parts like centrifugal starting switch, starting winding, starting capacitor, etc.
By the way, this motor has no brushes
The label on the motor is A.O Smith AC Motor
serial# S48E3 SER 2106
H/P 1/8 TYPE S
V 115 PH 1
A 2.5 SFA
HZ 60 AMB 40 DEG C
TIME CONT CODE U
FR48N INS B
HSG OPEN
Thermally protected TYPE M
EL2004V1
eceg
Keith Cress
Once again thanks fr the tips Waross.
By the way itsmoked, I checked Graingers, they do carry the type of motor I mentioned above. I'll keep this in mind for ordering in the near future. Thanks!
