Excel Thermo Add-in
Excel Thermo Add-in
Excel Thermo Add-in
Is there a good thermodynamics add in for Excel 2007?  I have the Water.xls add which worked fine with Excel 2003 but it does not seem to work with the 2007 version.
I would be using this for a steam power plant application.  Can anyone make some suggestions?  Thanks
RE: Excel Thermo Add-in
WinSteam works well.  WinSteam comes with DeskTop Steam, which works independent of MS Excel.  You may choose the 1967 or 1997 in either application.  See the following web site: http://www.techwareeng.com/prodWS.htm
