Measuring / calculating flow-rate
If I wanted to calculate the tonnage of a chiller's evaporator using the formula:
Tons = Delta_T x GPM / 24
How would I measure or calculate the GPM through the evaporator? I've been told to get it from the sales order for the chiller, but this would only give me what it is designed for and not the actual flow-rate.
RE: Measuring / calculating flow-rate
TTFN
- Strap-on ultrasonic flow meter
- Measure pressure loss through evaporator and compare to design pressure loss
- Pressure loss through balancing valve
- Measure pump head and extrapolate from pump curve
