mass moment of inertia
does " mass moment of inertia" of flexible body such as tire change during the motion?
Assuming the tire runs on soft ground without any deformation then goes on hard surface which cause deformation.
RE: mass moment of inertia
Yes, but not by much. If you are running a high frequency tire model such as Ftire it might just be detectable, at a guess.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
Some drag slicks probably have a decent change in inertia as they grow with rpm.
I doubt there are many passenger car tires which change inertia by a significant amount during normal driving.
