powerglide transmission output shaft
What type of spline is the 16 tooth output shaft on a powergrlide transmission. IS it a ansi standard or din standard what pressure angle and such? I need to machine some teeth on a shaft to match the drive shaft coupling.
RE: powerglide transmission output shaft
I did find some weld-on sleeves from Spicer.
http://www
ISZ
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
http://www.summitracing.com/parts/STR-U-1662/
and cut off the U-joint portion, probably for far less than the cost of machining such a piece. Note that they are still using the same spline on modern GM trannies!
ISZ
Pat
for site rules
Thanks again
