Existing joist information 32 L-AQ or 32 L-A-Q or 32 LA-Q
I am checking the capacity of the some existing joists and cannot find any information from SJI or other catalogs we have in our library.  I believe it may be a 32" LA joist but am not sure what the Q relates to. It does have some concentrated loads on it that may have leade the joist company to make it some kind of special joist.  I would appreciate any type of input. It spans approximately 44'0",  spaced at 7'-6" and is a roof joist built in or about 1962.  Thank you
RE: Existing joist information 32 L-AQ or 32 L-A-Q or 32 LA-Q
kschulte,
You may be able to post this over at SJI's website.
They have this form you fill out (http://www.steeljoist.org/investigation/default.asp ) and they were very helpful the few times I've used it.
Hope that helps.
RC
All that is necessary for the triumph of evil is that good men do nothing.
    Edmund Burke
