Catia script to swap Product and Part properties.
Hello All
Does any no if it is possible to write a script that can be run from inside or out side Catia V5 that could read and swap the properties. For instance If I have added a second set of properties say called My Part Number, My Revision, My Nomenclature and so on the script needs to take what is in these properties and swap it with the ones in the standard properties.
Know Fear
Know Fear
RE: Catia script to swap Product and Part properties.
TTFN
Would it be easy to do or are we talking a quite complicated script.
Below is some code to do the property swap to the currently open file in Catia. I do not know how to modify the properties without having the model open with Catia. Some other CAD packages I've used do have this functionality, but I have not discovered if/how to do this with Catia.
You could incorporate a batch routine process and iteratively open (in Catia) each file in a list and perform these operations.
I hope this helps.
brengine
CODE
Dim CatApp As INFITF.Application
Dim ActiveDoc As INFITF.Document
Dim PrtDoc As MECMOD.PartDocument
Dim ProdDoc As ProductStructureTypeLib.ProductDocument
Dim CatProduct As Product
Dim CatParameters As Variant
Dim sDocType As String
Dim sFilename As String
Dim sProd_PartNo As String
Dim sProd_Rev As String
Dim sProd_Def As String
Dim sProd_Nom As String
Dim sProd_Source As String
Dim sProd_Desc As String
Dim sMy_PartNo As String
Dim sMy_Rev As String
Dim sMy_Def As String
Dim sMy_Nom As String
Dim sMy_MadeBought As String
Dim sMy_Desc As String
'*** Variables that should be Defined ***
Const sUPDATE_VALUES = "Catia" 'Catia or MyProperties
Const sMADE_BOUGHT_STYLE = "StraightCopy" 'StraightCopy or MadeBought
Sub CATMain()
Set CatApp = CATIA.Application
On Error Resume Next
Set ActiveDoc = CatApp.ActiveDocument
If (Err <> 0) Then
MsgBox "No File Open. Routine Ending", vbCritical, "MyProperties"
End
End If
On Error GoTo 0
Select Case TypeName(ActiveDoc)
Case "DrawingDocument"
MsgBox "Does not work for Drawing files." & Chr(13) & "Routine ending", vbExclamation, "MyProperties"
End
Case "PartDocument"
Set PrtDoc = CatApp.ActiveDocument
Set CatProduct = PrtDoc.GetItem("")
sDocType = "PART"
sFilename = Left$(ActiveDoc.Name, (InStrRev(ActiveDoc.Name, ".") - 1))
Case "ProductDocument"
Set ProdDoc = CatApp.ActiveDocument
Set CatProduct = ProdDoc.Product
sDocType = "ASSY"
End Select
Set CatProduct = CatProduct.ReferenceProduct
Set CatParameters = CatProduct.UserRefProperties
sProd_PartNo = CatProduct.PartNumber
sProd_Rev = CatProduct.Revision
sProd_Def = CatProduct.Definition
sProd_Nom = CatProduct.Nomenclature
sProd_Source = CatProduct.Source '0=catProductSourceUnknown, 1=catProductMade, 2=catProductBought
sProd_Desc = CatProduct.DescriptionRef
sMy_PartNo = MyGetProperty("MyPartNumber")
sMy_Rev = MyGetProperty("MyRevision")
sMy_Def = MyGetProperty("MyDefinition")
sMy_Nom = MyGetProperty("MyNom")
sMy_MadeBought = MyGetProperty("MyMadeBought")
sMy_Desc = MyGetProperty("MyDescription")
If (sUPDATE_VALUES = "Catia") Then
'Update Catia Values
CatProduct.PartNumber = sMy_PartNo
CatProduct.Revision = sMy_Rev
CatProduct.Definition = sMy_Def
CatProduct.Nomenclature = sMy_Nom
If (sMADE_BOUGHT_STYLE = "StraightCopy") Then
CatProduct.Source = sMy_MadeBought
ElseIf (sMADE_BOUGHT_STYLE = "MadeBought") Then
Select Case sMy_MadeBought
Case "Made"
CatProduct.Source = catProductMade
Case "Bought"
CatProduct.Source = catProductBought
Case Else
CatProduct.Source = catProductSourceUnknown
End Select
End If
CatProduct.DescriptionRef = sMy_Desc
ElseIf (sUPDATE_VALUES = "MyProperties") Then
'Update MyProperties Values
Call MyModifyProperty("MyPartNumber", sProd_PartNo)
Call MyModifyProperty("MyRevision", sProd_Rev)
Call MyModifyProperty("MyDefinition", sProd_Def)
Call MyModifyProperty("MyNom", sProd_Nom)
Call MyModifyProperty("MyMadeBought", sProd_Source)
Select Case sProd_Source
Case catProductMade '1
Call MyModifyProperty("MyMadeBought", "Made")
Case catProductBought '2
Call MyModifyProperty("MyMadeBought", "Bought")
Case Else 'catProductSourceUnknown '0
Call MyModifyProperty("MyMadeBought", "Unknown")
End Select
End If
Call MyModifyProperty("MyDescription", sProd_Desc)
End If
End Sub
Function MyGetProperty(sProperty As String)
MyGetProperty = CatParameters.Item(CatProduct.Name & "\Properties\" & sProperty).Value
'Error occured if Property doesn't exist
If (Err <> 0) Then
MyGetProperty = ""
Err.Clear
End If
On Error GoTo 0
End Function
Sub MyModifyProperty(sProperty As String, sPropValue As String)
Dim CatParaItem As Variant
Set CatParaItem = CatParameters.Item(CatProduct.Name & "\Properties\" & sProperty)
If (Err.Number <> 0) Then
'Add Property
Set CatParaItem = CatParameters.CreateString(sProperty, "")
CatParaItem.ValuateFromString ""
Err.Clear
End If
On Error GoTo 0
CatParaItem.Value = sPropValue
End Sub
