Switching from polycarbonate to P.E.T.G.
When changing plastics in blow molding, polycarbonate to PETG, is it necessary to re-tool the mold?  Any help on this would be appreciated.  I have tried searching the forums, and do not know if I am using the correct search terms.
RE: Switching from polycarbonate to P.E.T.G.
I guess it depends how much of a size change you can tolerate. PETG had a greater mould shrinkage than PC.
A Google search will give you the data you need.
www.tynevalleyplastics.co.uk
PETG has a lot bless mould shrinkage than PET and is not all that different to PC. I would need to check data sheets for exact numbers. Eastman and Bayer should be able to provide reliable data to the exact difference in shrinkage.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Thank you both for you help, and suggestions.
